Fox 2.0 Coilover W/Ready Lift 2" block?
hammerhead2411
I've read a lot of comments regarding pre-load when it comes to "leveling" coil overs. Can I install Fox coilovers set @ no lift height, and add a 2" puck to lift the truck? Would this help with ride quality? Is it even possible/make sense?
Thanks
travisN000
Travis
Oregon
2021 F150 Powerboost CCSB
You can... if you search you will find people here that have done it; the preload on the spring typically makes the ride slightly stiffer... some like it for better cornering, but others don't and go the spacer route
SpaceWhiteF150
Montgomery, Texas
Yes, lots of people do that. Instead of using preload to lift the truck you can use a spacer. But personally, I like the feel of the front end with a little preload. To me it makes the handling “better”, totally personal preference. I have Bilstien 5100s with no preload right now and wish the front end had a little preload. But I’m unsure if this stays true with the fox 2.0 because it comes with a different coil spring installed. Food for thought!
