Forscan Digital Temp readouts on 2023 Powerboost with the 8" cluster
Blueonblue
Southern California
2023 F150 XLT Powerboost
IT Contractor
Has anyone been able to get these temps to show under the gauge like when the truck is overheating? I want to have a digital temp all the time and was able to change the IPC 720-07-01 to xxxx-xE5x-xxxx but nothing shows.
Ive been searching for this for hours and have tried multiple PIDs and restored to backups a bunch of times already!
Has anyone been able to make it work on an XLT with the 8" cluster? If so how did you do it?
{tpc}
Anthony
Berkley, MI
I’m fairly certain this doesn’t work on the newer 8 inch cluster. There was something for the older cluster but that went away with the newer one.
You can get a obd adapter with Bluetooth and get it on your phone with a scanner program, but not as elegant a solution.
