Forscan Availability
lambertchase04
Chase
Houston Texas
2014 F250 F150
Does anyone have access to Forscan around the Houston Tx area that could disable my rear park sensors? Willing to pay.
Porpoise Hork
Bret
IT Sys Admin
This forum is for the 14th gen F150. That said to my knowledge there's not any coding in Forscan to disable the rear parking sensors. For a 13th gen you should however be able to shut them off from the settings menu on the truck itself.
Give this a try.
Press the left menu button on the steering wheel to access the main vehicle menu.
Navigate to "Settings" and select it by pressing the OK button.
Go to "Driver Assist."
Select "Rear Park Aid."
Here, you can turn the rear parking sensors ON or OFF
Could also just unplug the speaker under the dash as well.
lambertchase04
Chase
Houston Texas
2014 F250 F150
I have a 2014 F240 but Forscan will work on it. It doesn’t matter if it’s 150 or 250. I need it completely disabled. I removed them due to a bumper change and it annoys me to see the pop up alert every time you put it in reverse. I have read a lot about it and Forscan allows you to completely disable it so I will never get that message again.
Porpoise Hork
Bret
IT Sys Admin
We can give it a shot to see if there's options in the IPC and BCM modules for it for the 13th gen. I'm up near the Tomball area. Feel free to DM me and we can meet up to knock this out.
Bigjim2
Jim
Tampa, FL
2021 F-150 Lariat PowerBoost
Sales
