F-150 2023 splash screen size adjustment?
Tropictundra
Washington
F150 Stx 2023
Hello,
I recently had APIM updated using FDRS and after the update, the splash screen size became small. Does anyone know how to restore the size to full screen using Forscan? Here's the picture for reference..
Ford F-150 F-150 2023 splash screen size adjustment? 20240913_065814
antho
Anthony
Houston, Texas
2024 Raptor 37
See what you have here. Make sure its a 3. I see you did a 8 to 12 upgrade so when you did the update in FDRS it loaded the 8" screen data. So that makes sense.
7D0-03-01xxxxxxxxx3--
Tropictundra
Washington
F150 Stx 2023
Hmm.. I changed it to 3 but looks like screen is still small. Do I need to change other values as well?
Ford F-150 F-150 2023 splash screen size adjustment? 20240913_175207
I've actually seen my Sync4 screen do exactly that just after an APIM update. Kinda freaked me out.
But after a soft-reset, it corrected itself. So it's possible for it to not be an Asbuilt value issue perhaps? But rather an update that hasn't completed successfully?
Tropictundra
Washington
F150 Stx 2023
Quick update: the screen went back to full screen after waiting about 10min or so after changing the value to 3, so it worked!! Thanks for all your help!
