Extended length running boards manufacturer or other solution?
HDT05
2024 F150 Lariat 502A FX4 5.0
Hi all
I am chasing a solution to the enable stepping up to the bed via either an extended length running board or some other solution. I'm a builder, I'm 6' and reaching the front of the bed requires a ladder or climbing up onto the bed. Frustrating as most of my tools are only an inch or two out of my reach.
I've looked the longer boards up on Ford Parts and if I'm reading it correctly I'm up for approx $1300 to swap mine out. I have the 6inch chrome running boards.
Does anyone know who the manufacturer is or can offer a solution such as another cheaper version or separate piece that attachs to the bed (eg a single step) at the side?
Thanks and cheers
Pedaldude
Arizona
There’s these:
https://www.amp-research.com/bedstep-2-side-bumper-step/2021/ford/f-150
Also there’s companies making full length, frame mounted rock sliders which can double as full length running boards and also offer some protection against door dings depending on design.
I will open my door and step on the sill plate to get better access to the very front of the bed, or step on the tire to get to the back but that can be tiring if you do it a lot. Also, be careful not to stick your fingers in the stake pockets or anywhere else that they can become trapped; since if you lose your balance and a finger gets stuck, it can get torn off or degloved (especially if you wear a ring).
780
Todd
edmonton
Also wishing I ordered the 6" extended boards. I overlooked that option when ordering.
I'm wondering if it's just a longer extension that can be exchanged with the shorter rubber /plastic part at the rear
? Or is it actually a longer board under the step pad?
(I know it's a Super Duty, but best shot I could find for what I was talking about)
780
Todd
edmonton
Does anyone know?
jofo
Joe
MA
2021 Lariat Powerboost 502A Smoked Quartz
My Lariat came with extended and they look to be a single piece design. I do not think you can add any extension. I will say that the Ford OEM ones are pretty nice. They are fairly robust and after almost a year still look new. I can see why they are so expensive compared to many of the aftermarket ones.
Todd
edmonton
Yeah, maybe it isn't someting that can be added.
Found this parts breakdown:
powerboatr
North East Texas, Piney Woods
2024 F250 King Ranch Chrome
Retired Navy Senior Chief
mine are extended and have the switch at the end to deploy them from outside
makes bed reach and washing an easier task
kind of hard or see in the pic, but they go back a good bit into the bed lenght
EcoPlat
Terry
South Carolina
2021 F150 XLT 302a EcoBoost
There’s these:
I would NOT recommend the Bedstep 2. I just put them on my truck and if you have anything larger than ballerina feet you can't get your foot on it to deploy, they are too tight to the body.
