Drive Mode Unavailable
Mauimaikai
2021 2.7 F-150 XLT 302a 4x4 SuperCrew
I've noticed on multiple occasions now over the past few months that while driving in sport mode my vehicle will randomly tell me drive mode unavailable and switch back to normal drive mode on its own. This is the only mode I've had it do this on, no rhyme or reason for when it does it. Anyone else have this happen?
Ford Motor Company
Official Ford Account
Ford
Dearborn
Hey there. I'd like to take a closer look at your drive mode concerns. Can you send over a message with your VIN and the name/location of your local Ford dealer to get started?
HSV_MIkeJ
Huntsville, AL
Website
www.music-by-mike.com
2021 Ford F-150 Lariat, SC Rapid Red
DJ
I have also seen that same thing happen a couple of times, but can put it in Sport Mode and drive it all day and it not happen again.
From the service manual, you might look for DTC's related to the PSCM. (Power Steering Control Module)
The PSCM monitors Can Bus for signals from other modules, like the transfer case module, and if it thinks it isn't communicating, it will return the SDM (Select Drive Mode) back to Normal even while the truck is in motion.
The communication failure can be caused by a battery not providing ample voltage to the various modules, even just momentarily. It also states that the technician should look for harness connectors that are loose or damaged.
There's as many as 47 modules in these trucks. It's amazing that there wouldn't be one bad pin, wire, connector, ground bolt/strap.......
DBL R
Jarred
Washington
2021 F150 powerboost
PA
this happened to me once. No dash lights no other warnings. I switched back to sport and it stayed in it. No idea.
"Steve"
"Steve"
NTX
21(1).302.PB.157.OX
noticed mine doing this a few times the last couple days.
"Steve"
"Steve"
NTX
21(1).302.PB.157.OX
just checked and seeing this dtc
atcm u2009:9e-08
jrod4905
Johnny
Georgia
2020 f150 xlt 5.0
So I’m kinda in the same boat but I have a 2020 f150 xlt 5.0 10speed I had the little 4inch screen cluster and just upgraded to the 8inch screen did everything step by step using forscan and all that, everything seem to be in working order until I tried to switch drive modes when I click the button nothing pops up on my screen not even a “ drive mode unavailable” so I pulled up forscan and I have a “IPC U0405:56-0A invalid data received from cruise control module” but my cruise controls works
I’m just stumped
SilverPigeon
Australia
I’m just stumped
On gen14s, the CCM on.y contains the VIN as far as configuration is concerned. That's why it doesn't appear in the spreadsheet. I looked at the gen13 (yours) sheet and it's not there either. So, if you didn't change the CCM, then the best bet is to ask them on the gen13 forum I think.
jrod4905
Johnny
Georgia
2020 f150 xlt 5.0
I’ll try there thank you
