Post whatever dealer has for resolution because it's definitely a strange issue.
@LetsbeFrank FIXED!! Ford originally installed some INCORRECT 110v power outlets in the left rear of the truck bed. Dealership did a swap and it ALL works normal again!![]()
If the repair at the dealership doesn’t work I’ll give this a go. Currently waiting to see the “electronics” guyFYI, I was having similar issues with my inverter along with a number of other electric gremlins and a new H8 AGM battery cured them all. Not sure if this is your issue, but worth check voltage and battery.
Did you have to get a larger strap for the H8 and if so where did you get it?FYI, I was having similar issues with my inverter along with a number of other electric gremlins and a new H8 AGM battery cured them all. Not sure if this is your issue, but worth check voltage and battery.
Nope. Current strap worked fine. The battery was 3” longer but no wider than the much smaller stock battery. I have a 2021 3.5eb fyi. Not sure the design on other trucks.Did you have to get a larger strap for the H8 and if so where did you get it?
You'd need to share the specs of the winch. If it draws more than 3A @ 120V, it's probably not going to work. I'm inclined to say no, but that's only a guess.I'm thinking of buying a portable electric winch to load equipment in the back of my bed. It is a rather small one with a max of 750lbs. The equipment I need is only about 225lbs. Do you think the inverter would handle that? I'd probably only need 20sec or so out of it. I'm inclined to say no, but if not it is a wasted idea.
Can you power it off of your trailer connection plug instead?I'm thinking of buying a portable electric winch to load equipment in the back of my bed. It is a rather small one with a max of 750lbs. The equipment I need is only about 225lbs. Do you think the inverter would handle that? I'd probably only need 20sec or so out of it. I'm inclined to say no, but if not it is a wasted idea.
I have a 2022 with the same issue, power outlets only work at night and not during the day. So the fix is replacing the bed outlet?
Would you happen to have the part number for the outlet?Yes. The bed outlet repair fixed my issues.
