Coolant level
Texas2022XLT
2022 F150 XLT 302A
I’ve got a 2022 with the 3.5. Doesn’t get drove much only 2 oil changes a year as I never hit the 5K miles and change it anyways. I popped the hood today and notice the coolant level was at the min line. I never really paid attention but does that seem reasonabl on a two year old truck. I’ve heard of coolant leaks so that why I’m asking with a year left with warranty. Thanks for any informatio.
FaaWrenchBndr
Denver, IN
‘24 XLT Powerboost
Guess you need to drive it a bit and check for leaks
Old Hat
IL
2+ years at 13,000 miles and I topped mine off for the first time a few months ago. Maybe 12-16 ounces. Never a sign of any leaks. I monitor regularly.
Gros Ventre
Western Wyoming
I was concerned with my engine coolant. Its color just looked odd to me as if there was an exhaust leak into it. Had a chemistry analysis done on it. Results were all is well. So I keep an eye on it, but it's rock steady, even if at the low mark.
Texas2022XLT
2022 F150 XLT 302A
I appreciate all the responses, coolant color looks good. I‘ll keep an eye on it and add a little at my next oil change which is next week.
Kanuck
Winnipeg, Manitoba
Retired Electrician
The coolant is 50 percent water and 50 percent glycol. Water evaporates slowly over time. Keep it topped up. Mine does it as well.
Gros Ventre
Western Wyoming
The coolant system(s) are sealed unless an overheat event takes temperatures above the relief setpoint. So evaporation should not be an issue. Also some of us run more than 50% glycol. In my neck of the woods we can see -40ºF and even lower on occasion.
Kanuck
Winnipeg, Manitoba
Retired Electrician
I also see -40 up here in Canada. I have had to add anti freeze to my truck once or twice...not much but some. No leaks....no puddles on the floor...
Gros Ventre
Western Wyoming
Well, you're lucky... the freeze point at 50% is -34ºF. I shoot for 70% giving a freeze point of around -70ºF.
fmdog44
steve
2012 F150 XL
I put 100% coolant in my Ram hemi years ago thinking it was 50/50. The heads warped and thousands of dollars later I was back on the road Doh!!
Severdog
Craig
Landrum, SC
Trader
I’ve got a 2022 with the 3.5.... and notice the coolant level was at the min line.
My 22 PB/3.5L had about 30k on it when I noticed the primary tank was slightly below the "min" line. No leaks anywhere and no reason to suspect head gasket. Just topped it up and will keep an eye on the level. Apparently this is very common.
Kanuck
Winnipeg, Manitoba
Retired Electrician
I don't know what type of glycol you use...mine at 50% mix tested to -45 about a week ago. If it gets that cold here.-70...hell I stay indoors.
Hans Moleman
SF Bay
Are you sure it wasn’t on the min line from the factory?
Mine was in the min line new from the dealer. I waited for 5k miles on the first oil change and it was topped off to the max line. 6k miles later now and it’s still at the max line..
RCSB
Eugene
Kentucky
2024 F150 RCSB
My new truck is near the minimum line.
Texas2022XLT
2022 F150 XLT 302A
I can‘t say honestly if it was at the min line or not when I got two years ago. I checked under the hood a lot during the first year as I had one of those bad batteries that I finally got replaced under warranty. I usually look at the fluids and didn’t recall it being at the min so thats why I wanted to ask here. Made me a little nervous with one year left on the warranty, wish I would have bought an extended in the first year with so much electronics on these trucks.
