Conversion to paddle shifters is it possible?
superfordman
Troy
NE CO
2024 Raptor 801A
Precision Ag Guru
I appreciate you responding. It seems superfordman hasnt been on in a while either. Ill look over everything again. It has to be something simple.
Do you have console or column shift truck? Looks like you have the right wires hooked into looking quick at your pics. Just use a volt meter and set to resistance at the wires going to taps to see if you see any change when you hit the paddles, you should and that will let you know if you have signal from the wheel to there or not.
syclone50
Jeremy
Utah
2022 F150
I did iget them working. I had 2 of them crossed. Double checked them and found the issue. Thanks for your info through this thread I wouldn't have attempted it with your input!
superfordman
Troy
NE CO
2024 Raptor 801A
Precision Ag Guru
Mxkx36
Jimmy
Arkansas
2023 f150
Transportation
Hi guys, this may seem like a silly question.
Is it possible to convert a 2021+ F-150 steering wheel to a Raptor steering wheel with paddle shifters. I seen where people have put Raptor steering wheels into the earlier model F150s. Does anyone have any information on doing The conversion on the latest f-150s???
Please I'm open to all ideas and suggestions. I recently supercharged my truck and notice that the transmission likes to search for gears sometimes. My truck has the column shifter But when I'm dragging it gets a little bit sketchy trying to control the with one hand on the steering wheel and one hand on the column shifter.
I did it on my sxt and it works like a champ mine was also colum shift and I converted it to consol shift
Ford F-150 Conversion to paddle shifters is it possible? IMG_6117
