Countryeemann1
A huge factor in purchasing a Ford was the onboard inverter for our camper. Well, we quickly found out that certain things either don't run or don't run correctly on the inverter. The items I'm talking about run fine on any other platform.... other generators, other inverters, house power, etc. This is also not a load issue... everything we're having issues with is drawing less than 2000 watts.
Let me say that I have extensive experience in power generation both large scale (commercial utilities) and small scale. We personally own several generators, inverters and inverter/generators and have for many years.
Whatever the platform, every one of them is supposed to do one thing... produce 120 volts at 60 Hz (plus or minus a small percentage).
So our truck inverter is producing about 120 volts (good) at a frequency of around 160 to 180 Hz and it is very obviously causing problems with certain electronics.
Ford so far has been epically useless. Numerous calls to Ford and hours on the phone have produced nothing. The dealers know nothing about these things other than replace if it throws and error code (no error code). Dealer plugs in a power tool (or whatever), sees that it powers that and says it's fine.
This has been going on for several months now trying to get this resolved. Today I checked one sitting in the dealer lot and it's apparently the same way. Not even sure what to think about that.
Bottom line is we can't use this for the intended purpose and it's obviously not producing what every normal generator or inverter in America can do... produce 60 Hz power. Even $15 inverters produce 60 Hz.
Again, this inverter package was a major deciding factor in our purchase. At this point, it's been tons of frustration and I don't even know where to go from here.
