Clicking noise from dash while applying brakes in drive
Bknelson83
Brandon
2021 F150 XL
Noticed today a clicking noise while I apply the brakes. I know this can happen in park but what would be the reason for this to happen in drive? It sounds like a relay clicking. Happens after I got 20 mph then is consistent even below that speed.
Icbmredrat
Wade
Toronto
F-150 XLT 4x4 Supercrew
When the windows are fully up, I can hear a “click” noise every time I apply the brake. It’s not loud but if you focus you will hear it.
Indiana2021F150
Indiana
2021 F150 Lariat
I, too, have same issue. Just started with approx 700 miles on odometer. Do not have at low speeds or when brake vacuum is “full”. Anyone else have this?
Asphaltman
Salt Lake City
2022 F150, 2021 F150, 2018 F-150 1997 F-250H
Entrepreneur
I have the same issue and it seems to be intermittent when it happens.
netramsilver
crowley, la
2021 Ford F-150
I am having the same issue. Ticking noise every time I brake-always around 20-30 mph. Has anyone had any luck diagnosing the issue?
Lr3369
Tim
Joplin MO
2021 F-150
i have the exact issue, the dealership replaced the brake mastercyliner and it did NOT fix the click
every time i press the pedal i get a click & it is super annoying
Lr3369
Tim
Joplin MO
2021 F-150
i thought i had the dealership convinced that im not hearing things so they agreed to replace the master cylinder, it did not fix the issue.
Ford Motor Company
Official Ford Account
Ford
Dearborn
I thought I had the dealership convinced that I'm not hearing things so they agreed to replace the master cylinder, it did not fix the issue.
Hi there, Tim! I'd like to take a closer look at your truck's break issues and assist you in getting that clicking sound addressed. To get started, please send us a private message with the name and location of your dealership. Thank you!
BILDOZER
BILL
Seattle
2025 King Ranch Powerboost /2021 Ford F150 Laria t2.7.
Going to work.
I also notice the clicking Sound mostly when brakes are applied firmly. It definitely sounds like a relay/switch. This has happened since new.
daemonic3
Terry
Sacramento, CA
2017 F150 3.5EB
I also noticed this but not from me using the pedal, I get it when using the adaptive cruise and the computer is applying braking to maintain speed on low to moderate downgrades (or if a slow car is in front of me).
It definitely sounds like a relay/solenoid engaging, but at least in my case it is not pedal related at all.
Gabes
Jon
Hugo, United States
2018 F150 2.7 EB, 2021 F150 PB
Machinist
I'm getting the same. Sounds like it's up under the motor somewhere. Mine does it every time I hit the brakes and it also sounds like there is two stages to it. When I hit the brakes and when I hit them even harder. It's actually pretty loud on mine.
Mladen5375
Pittsburgh
2022 F150 502A Powerboost, 2023 Expedition SPP
Mine just started doing this about a week ago right after I hit 1,000 miles. It is very annoying to me, should I take it in? Something to be worried about?
Ford Motor Company
Ford
Dearborn
Hi there. This clicking concern doesn’t sound like something we want you to experience with your F-150. Could you please send us a PM with your VIN and the name and location of your Ford dealer? I'd be happy to look into how I can assist you on my end.
