Canada to USA programing
MichF150
MichF150
GR MI
2021 F150 Powerboost
Did you make changes in Forscan or just in the cluster? If you made the Forscan changes, those should report back to the mother database eventually, but maybe in you case, an OTA update rolls out before that happens, so then the values recorded in the Ford system just gets written back to your truck.
Your changes actually become your as built data eventually. It will stick.
superfordman
Troy
NE CO
2024 Raptor 801A
Precision Ag Guru
Forscan changes don't change.
I lose my user configured settings with miles showing and I have multiple screens turned on under "my view" that all get reset.
My last update was a PCM update too so I'm confused why the hell it messes with my dash but I'm used to it at this point. Every update means using steering wheel buttons to fix my settings.
It's annoying, and an odd issue, but not the end of world.
Ok, that's pretty common whenever an update happens then depending on the module, or even if I make changes to the IPC or BCM, it likes to reset those. It was an issue early on with the 21 trucks where it would do it randomly and frequently, but I think they got that pretty well sorted out now.
Yeah I thought it was exclusive to IPC updates but last update was PCM and everything reset again. A very annoying "feature."
Tripper23
Matt
Kansas
Lincoln Navigator, F150
Yes, just poke around in the IPC and APIM easy config modes and there are a few values you can change to US. I just had to change the same in my sisters 22 expedition that originated from the great north.
Do you think this will work on a 2022 Lincoln Navigator?
