Can you set a default drive mode?
dantheman
BCS TX
21 XLT powerboost
I just got my 21, and I keep having to change it from normal to eco for driving around town. Is there a way to make that the default mode?
Daily22ssv
Adam
Tx
21 F150 powerbost
Tech
I've been wondering the same thing.
KBKEITH
You can’t, at least not to my knowledge.
It’s a little awkward to me when you rotate the knob to get to maybe “Sport”mode and you by chance rotate to “slippery” mode on the way and the hubs lock to 4H. I’m not really liking how that works.
gadiedrick
Gary
Galena, IL
2021 Ford F-150 XLT 4x4 SuperCrew long bed hybrid
retired USN Chief Petty Officer
Also, do you have to select a mode every time you start the vehicle or does it default to the mode it was last in when it was last turned off?
MidnightM
J
2018 F150 SCREW Sport 5.0, 2021 F-150 SCREW Sport
My 18 has always required mode selection after each startup. I just leave it in normal unless it’s inclement weather.
dantheman
BCS TX
21 XLT powerboost
The problem is it always defaults to Normal. With the powerboost it will stay on electric quite a bit more when your in eco mode, which is great around town. Its not a bad thing, but I am just lazy and would prefer it just hold the mode till I change it.
discothan
SW Michigan
2021 F150 XLT
Understood. I'm just EcoBoost, but the desire is the same....go to my preferred mode and stay until I tell you to change.
Knickell
Mazda Protege, Ford F-150
For those of you that have your trucks already, can you switch the truck to Sport mode while it is in motion, or will that hurt the transfer case? Can the truck be in motion while a “4x4 Shift in Progress” is happening?
I have a Sport mode on one of my other vehicles and it’s nice to just be able to turn it on and off as needed.
KBKEITH
Yes, you absolutely can switch to sport mode while the vehicle is in motion. That’s typically how I change drive modes.
What I don’t like about that is when I want “sport” mode and I rotate the knob it’ll sometimes momentarily land on “slippery” mode or another mode that activates 4H and the hubs will lock.
The truck can be in motion when the “4x4 shift in progress” is happening.
dman17
Douglas
Swanzey NH
I know with my 18 F150 I was able to purchase a "Drive Mode Memory Module" for around $50 and it took about a hour to install
YzermanTopShelf
Tom
California
2021 F-150 Lead Foot Lariat Powerboost
I’ve found that the behavior on startup is a bit inconsistent. If I have the car in eco mode when I turn it off, then I will be asked if I want it in eco mode when I restart. The one exception I’ve found is when I do a remote start with the app. With a remote start it always goes to normal mode and there isn’t a prompt asking if I want eco mode
Knickell
Thanks for the info. I was trying to read through the online manual last night as well and it wasn’t the easiest to decipher. Good to know. There are sometimes you just need to have the Sport mode for a few seconds and stopping to change would become arduous very quickly, and kinda defeat the purpose.
KBKEITH
Sure, no problem.
The previous gen trucks had a button mounted low on the console shifter that you pressed to cycle through the drive modes. That could be done on-the-fly as well.
