gagliano7
I have the start x in my 2023. Simple install and uses the stock remote. Never had any problems and when you get in your truck it says insert key and turn to on. Seems to work just like original remote start.
I used a 12volt solutions with my old Tacoma and it worked great. But I am still trying to found a factory solution… Hopefully someone can chime in if that’s possible with forscan…You could try out 12volt Solutions, but I am not seeing 24 listed.. used them for my 17 F250, used the existing key fob with some programming.
https://www.12volt.solutions/products/2021-ford-f-150-remote-start-plug-play-kit
Update: I did get the truck and the fordpass app works fine to start it.
That was the case with mine.So what you're saying is the xl has everything needed for factory remote start except the original supplied keys don't support it?
