Bushwacker Fender Flares?
Poalpo
Mass.
I was not sure about these BW flares. But price was not bad so I had local shop order some for test fit. Looked ok so had them painted and installed. I’m very happy with them, and I’m very picky. I wasn’t looking for huge flares that would require lift and wide tires with 0 or - offset to look good. I wanted to maintain decent gas mileage and
have aftermarket wheels and AT tires.
Looks absolutely awesome. I think painting them to match body is key with these flares. Those stock black photos dont do them justice.
Are those 35s on a level? Looks that way.
chill_will
Will
Montgomery, TX
2021 Powerboost F150 Platinum 4x4
Ford F-150 Bushwacker Fender Flares? 738EB966-E83D-4344-8267-A7A40467530D
Anyone have pics of the extend a flares paint matched? I like the smooth look similar to the raptor rather than the bolt on look.
Cardoso
Mauricio
Sales
This is by far one of the most factory/clean/OEM looking but that is actually modified - trucks I’ve seen. Great job!
dm5point0
Atlanta, GA
2021 F-150 Lariat FX4
UPS
I have the Air Design flares with 305/55/20s on 20x9 -12mm offset. I love them and the way they follow the lines of the truck, but my dealer can't seem to match the Start White paint on the truck. The flares are about a shade brighter than the rest of the truck.
Ford F-150 Bushwacker Fender Flares? PXL_20220319_220840731
SuperRaptor
2018 Lariat 502A
You can also buy the Raptor flares themselves.
DennisG
Dennis
California
No drilling or adhesive. They use several of the existing holes on the bottom of the wheel well and then have clips that attach to the inside of the fender well. Was surprised that the clips hold so well. here's the install guide
View attachment BWRIBWF-20963.pdf
BHunted1
Sumner County TN
Unless you just have plain star white, they can't or don't know how. The paint is called Star White, but if you have Star White Metallic Tricoat, it will look different. If you order touchup paint for instance, it will just be star white. It will not look the same on the truck though. Check your window sticker and then look at the paint code on the door. Would suck if you had any major paint damage. The other metallics like Agate black, same thing.
Guard777
Chad
Lake Nebagamon WI
What do you have for wheel offset and tire size? Looks great!
briancf67
Brian
'23 F150 Lariat FX4 502A
Cybersecurity Services
These look so much better and are available from Ford Accessories for the 2021 F150 as well'
What tire size, wheel size and offset are you running? Are there any clearance/rubbing issues in front?
Calson
Monterey CA
I like that both their OE style and Extend-a-Fender flares can be put on with no holes needing to be drilled in the sides of the truck. At $420 for a set it is very reasonably priced.
The flares along with running boards provide a lot of protection for a truck.
