Brakes Squeak on and off!
David1234
Lake Stevens, WA
2021 F-150
Mine follow this same pattern also, function well. Just concerned I'll never be able to tell when they are close to worn other than pulling a wheel off.
There is a TSB recall for some 21's and 22's
I even printed out that TSB and handed it to the dealer when I asked them to look at the brakes.
His response was, "oh, I haven't heard of that one."
I'm going to bring it up again the next time I bring my truck in for service, but I'm going to try at a different dealership.
STexas90
STexas90
Houston Texas
2022 Ford F-150
Hmmm I had the recall down where they just wrapped the parking brake because it can run don’t know if that is different. I agree I won’t know if they are ever worn it’s just weird even in hot weather no humidity they still do it.
astro_fusion
IE, CA United States
2022 F-150 supercab, 1990 Bronco II
I believe this is a different TSB just related to noise complaints, that wire harness chafe issue was an actual recall, would deploy the parking brake while in motion.
STexas90
STexas90
Houston Texas
2022 Ford F-150
Ok good to know have you done the TSB? Make any difference?
Cobraman428
Jerry
Tampa Bay Florida
VP of IT
Had a real bad noise from the front driver side wheel. Leaking caliper and pads were dragging. Truck in the shop now and dealer is replacing caliper. Sounded like a 18 wheeler stopping every time. Have your brakes checked out. My truck is still under 3/36 warranty. NO COST. 17k miles.
Update. LF caliper was replaced and truck's brakes are working normally wo any noise. Don't write off the noise as normal. Yes, Ford's Semi-metallic brake pads can be noisy. But my issue seemed to much more than normal Semi-metallic brake pads noise.
