Black Exhaust Tip options?
Bikertrash
Phil
ND
2022 Lariat PB 502A BAP FX4 SCrew Aggate BAP Tow
Actually just painted it and left to cure in the sunshine turning it every 10 minutes or so.
Used a 2x2 piece of wood and screws to hold it from the inside while painting and curing.
Used high temp ceramic engine paint.
Tobstertx3
Fulshear, Texas
2022 F150 Lariat
But that is a 5" inlet. Will it work on the 2021/2022 F-150's 3"pipe?
Sorry, posted link to incorrect size but if you select your year of truck it should give the correct size. There are a number of different inlet sizes.
You can also reach out to @Stage3Motorsports here and sure they can provide the correct item.
jaggah
jaggah
Joban
Brampton
22 F150 Powerboost
I was anxious painting the chrome tip on my BAP but I took my time, did multiple thin coats and it ended up looking great.
How hard was it to remove the tip?
Bikertrash
Phil
ND
Tip came off easy, grabbed it and twisted slightly as I pulled. Mine had “ears” on the inside that use friction to hold tip on.
jaggah
jaggah
Joban
Brampton
22 F150 Powerboost
Im not sure why the new tip requires trimming then do you think I can install it straight on?
z-man
Las Vegas, NV
2022 F150 Lariat Powerboost
I painted mine with high temp ceramic primer and then black. I had to bake it 3 times at different temps for the primer and the black paint. It has been on since November and is holding up great.
Ford F-150 Black Exhaust Tip options? PXL_20221130_181815819
diambo4life
OKC
2022 Lariat Screw 4x4
Assassin
I bet you can see it from the back though.
TylerNinetyTwo
Phoenix
2022 F150 XL Regular Cab
@diambo4life you can't unless you kneel down and look under the truck. when you mount the exhaust tip you face the clamp up so it's hidden really well. i'll be making a thread with all the stuff i've done to my truck and i'll be sure to snap some photos of it to prove that it's actually really clean. keep in mind if you go this route you have to chop off 7.5 inches of your exhaust pipe.
dolsen
KY
2022 Rapid Red 701A
You don’t HAVE to. I didn’t when I installed mine and I’m glad I didn’t because I just removed it while returning it all to stock and was able to slip the chrome one right back on
TylerNinetyTwo
Phoenix
Of course you don't have to but it doesn't look very good if you don't cut the tail pipe. I'm never going back to stock so i didn't mind chopping it.
TylerNinetyTwo
Phoenix
@dolsen you have yours mounted farther down the tail pipe which is completely fine but I have mine mounted in line with the side of the truck and when i did that i could easily see the stock exhaust tip which did not look good at all.
dolsen
KY
2022 Rapid Red 701A
It didn’t stick out past the wheel and only barely stuck out past the bed. The stock exhaust tucks up under the bed a little bit. I think it looks fine. Your *opinion* is that it does not look good.
To each their own
