Best AT tires for snow?
Mtnman1
Tod
2022 F150 RCSB FX4
Semantics I surmise. My point is any “all weather” tire, is going to be a compromise all of the time. It will do lots of things ok, but nothing as well and a dedicated tire - Especially in ice/snow.
You can buy an all season tire. You can buy an all terrain tire. Different models of tire. Not really semantics.
I have never felt "under tired" in the snow with the Falken or Cooper AT's. I have never been stuck or unable to travel. I have never been out of control. And we get a lot of snow here in the NE Ohio snow belt. And living in the boonies means roads do not get plowed for a day or 2 after the snow.
I see no point in a dedicated snow tire. They will provide me nothing more than I already have, especially for the added cost and time.
SumGuy
F150 (perpetually on order)
Drugs
I live in the Rockies, and the abilities of a dedicated snow tire are like night/day vs an all terrain / all season (whatever you want to call them).
You do you though! I am not here to change your mind, just share info.
RickBullotta
Rick
Pennsylvania
2021 F-150 Lariat Powerboost
I went with Pirelli Scorpion All Terrain Plus based on TireRack ratings for snow and general performance. Note that these are NOT the ATR's that come OEM on some trucks. I run them at 43 psi normally and 47 psi when towing.
Oh, and more people drown in swimming pools each year than are killed in mass shootings. Data and all.
Derekmson
Denial
Phoenix, USA
Ford 150 2012
I recently installed a set of Falken WildPeak All-Terrain tires on my F150, and I believe they are among the top-performing year-round tires, particularly excelling in snowy and icy conditions for half-ton trucks. It's worth noting that some reports suggest they wear out relatively quickly when used on heavy-duty trucks (as I experienced with my RAM 2500). However, on my F150, these tires https://www.corwheels.com/best-all-terrain-tires-for-snow/ have proven to be highly effective in handling the winter conditions we've encountered thus far.
stlgrym3
SoCal
2023 F150 PB Lariat
Check the tire store websites and the manufacturers' websites as they will provide a rating for snow and also for wet pavement as traction on both is important.
The foctory Hankook DynaPro AT2 tires are considered to be excellent for snow. An alternative would be the BF Goodrich T/A KO2 ties that are "severe snow service rated".
Factory tires need 35 PSI which is not a problem. My last 2500 pickup had Load Range E tires and other than a tire store I needed to get the 80 PSI from a Viair compressor I bought. With a D range tire 65 PSI is needed and that may be more doable at a gas station.
nice to know, i was pondering if i should swap out the Hankook DynaPro during winter.
tony72cutlass's'
Tony
Halifax
Strongly recommend trail terrains they are highly rated just got a set
Ford F-150 Best AT tires for snow? IMG_3410
