FXDBRP
I recently noticed that the cargo lights in my late 2021 trucks bed will never completely “turn off”. They very dimly flicker almost as if some residual or phantom power is trickling into the LED cargo lights. It happens constantly even after the truck has been locked and the key has not been nearby for hours. The lights will momentarily get slightly brighter if the drivers or passenger door handles are touched maybe waking up the modules. The top mount 3rd brake light is also not affected and all the other lights are still fully operational and function as normal otherwise shutting off completely. I connected the truck to Forscan and I have a DTC code for B153E Trailer Hitch Light Output and if I run a self test on the BCM I also get a B14D8 Bed Lamp Output code. I’ve noticed no issues with trailer lights connected so I am not sure what is causing this. I thought it might be a bad switch so I also removed the switch in the bed but that seems to only send a signal to the BCM and so the lights still flicker even with the switch disconnected. Anyone else run into something like this or is this normal?
