Battery charger recommendations
Ghurst
Indiana
21 f150 3.5 eco boost king ranch, 601a
Carpenter
I got a new to me 21 f150 king ranch with the 3.5 eb. I guess I need to charge the battery but my old charger isn’t compatible with the AGM batteries. Any recommendations on which charger to purchase or ones to stay away from?
Thanks
Probity
Covington LA
2018 F150 Scab XLT 2.7EB 2wd
Thanks
I've only used relatively low amperage (less than 5 amps) "maintainers" that say they're OK for AGM batteries.
Victron's get high marks from users, don't know how good the Bluetooth function is. For AGM's, recommended normal mode (14.7V) for charging.
Amazon.com: Victron Energy Blue Smart IP65 12-Volt 5 amp Battery Charger (Bluetooth) : Automotive
Lots of folks use NOCO, a variety of models out there.
I currently use a fairly cheap Battery Tender Plus 1.25 amp maintainer, no issues yet in last year or so.
Amazon.com: Battery Tender Plus 12V Battery Charger and Maintainer: 1.25 AMP Powersport Battery Charger and Maintainer for Motorcycles, ATVs, UTVs - Smart 12 Volt Automatic Float Charger - 021-0128 : Automotive
Ghurst
Ghurst
Indiana
Carpenter
I bought this one based on everything ive seen in these and other F150 forums. Its been great. I believe its helped with my OTAs, by raising the SOC...
https://www.amazon.com/gp/product/B007ESQW08/
Im hoping for the same results! I’ll probably be replacing the battery very soon, but want to make sure the new battery is fully charged before I reset the BSM. I’ve read on here that’s the way to do it.
Kanuck
Winnipeg, Manitoba
Retired Electrician
I use a Noco Genius 5. No matter what one you get, Do not connect it to the negative battery post. It gets connected in such away that the little black sensor is between the connection point and the negative battery post. This is so the truck knows what is happening to the battery. It's all part of Ford's charging logic.
Kanuck
Winnipeg, Manitoba
Retired Electrician
Key on engine off
Wait till battery light stops flashing
Flash brights 5 times
Hit brake pedal 3 times
Battery light should flash 3 times
Done.
Should only do this when installing a new battery. Reason is, this also resets the in service clock which changes the charging strategies.
PB2021
Rob
2021 F150 Lariat Powerboost
I recommend the NOCO Genius 10. Works great as a charger, tender, and recovery/repair unit. Generally it’s just used for maintaining the truck but when my snow blower battery died the repair mode brought it right back. Also charges our camper battery quickly if it gets down.
LouDog
Sean
Grand Junction CO
21’ Lariat Powerboost
Agreed. Noco genius 10 is great. I was concerned that the supply mode would not be enough for FDRS programming because its only 10amps, but it worked like a champ even through a marathon 6+ hour update for the IPC.
Ghurst
Ghurst
Indiana
Carpenter
I do have several updates to do ( once I work up the courage!! Lol
ks54703
Ken
Central Wisconsin
22,XLT,302a,2.7EB,19, 2.0EB Escape,79 Magnun GT. 05 Magnum RT
Retired IBEW Local 14 inside wireman
MetalCord
North NV
2023 XLT 302a PowerBoost
IT Specialist
I'll echo the recommendation for the NOCO Genius5. Although it appears the NOCO Genius line in general is very good.
cheesedogf150
CheeseDog
Toronto, Ontario, Canada
2022 F-150 Lariat
I’m using the Noco g3500. Solid.
keeps moving from vehicle to vehicle
Cobraman428
Jerry
Tampa Bay Florida
VP of IT
