Are skinnier snow tires OK?
Mosey
2021 F-150 Powerboost
I have been looking for some used wheels for my 2021 PB SCREW that I ou,d use with winter tires.. I came across a set of wheels off of a 2019 F-150 with Hankook I-Pike winters on them. The wheels have a few blemishes but they do come with TPMS sensors. The tires are 255/70R18 compared to the stock size of 275/65R18. Specs show that these tires are the same diameter.
My question is simple - are there any downsides of using a skinnier tire? Thanks.
Kanuck
Winnipeg, Manitoba
Retired Electrician
You should be fine... Your only talking about 3/4 of an inch difference in width. If the price is right.... I would go for it. I run 265 winters and 275 summers
Old Hat
IL
Agreed, skinnier is better on snow. Wider floats on top, skinny gets to pavement. I learned this driving two otherwise similar Pontiac Trans Ams through winters. Keeping the same diameter as stock is wise also... doesn't mess up gear ratio, speedo, and everything else.
slow3v
Narrower tires perform better in the snow - factual. More weight on a smaller contact patch.
Gutshot
Matt
2022 XLT screw
Aggregate junkie
All of the above 100%
Polo08816
MD
2014 BMW 335i
+1
Tire compound and tread design trumps tire width. All else equal, tire width will matter.
Mosey
Mosey
Thanks everyone for your advise. I plan on picking the wheels up.
Mtnman1
Tod
2022 F150 RCSB FX4
Ok? You want skinnier tires for snow.
Wide tires are the worst possible snow tire
UncleWillie
Willie
N. Georgia
'23 Tremor 402a 3.5 EB
There is some very cool stuff out there that shows good comparisons. I love this video:
Its shows the difference between fat tires vs. pizza cutters. Tese days, giant wide tires are all the rage, but pizza cutters have been used across the globe in a ton of different non-pavement scenarios. There's a reason...
