Any Idea what this code is for; B15E1:97-08
BlackSheep
Indiana
2021 F150 Powerboost (Job 2)
I scanned my truck today with my Autel. It found this code under, CMR (Camera Module-Rear) B15E1:97-08. The description says Driver Side LED(Light Emitting Diode). I don't see any lights not working. Does any know what this error is stating?
BlackSheep
BlackSheep
Indiana
Thanks for the reply; I guess I'll bring it up with the Dealer next time it is in since it came back after I cleared it.
Buyer2021
central TX
retired!
FWIW, this is what a search of the "Master DTC Chart" in the Workshop Manual revealed:
  • [DTC] B15E1:97
  • [Description] Driver Side LED: Component Or System Operation Obstructed Or Blocked
  • [Pinpoint test] D: B115E:97, B15E1:97 OR B15E2:97 (Interior Camera System)
Nope, I've no idea what any of that means in plain english :unsure:
Mike G
N. AL, USA
  • [DTC] B15E1:97
DTC Fault Trigger Conditions
DTCDescriptionFault Trigger Condition
CMR B115E:97Camera Module: Component Or System Operation Obstructed Or Blocked A continuous memory and on-demand DTC that sets when the driver status monitor camera module detects that the camera is obstructed or blocked.
CMR B15E1:97Driver Side LED: Component Or System Operation Obstructed Or Blocked A continuous memory and on-demand DTC that sets when the driver status monitor camera module detects that the driver side LED is obstructed or blocked.
CMR B15E2:97Passenger Side LED: Component Or System Operation Obstructed Or Blocked A continuous memory and on-demand DTC that sets when the driver status monitor camera module detects that the passenger side LED is obstructed or blocked.
Possible Sources
  • Blockage or obstruction
  • Driver status monitor LED
  • Driver status monitor camera
Visual Inspection and Pre-checks
  • Inspect the driver status monitor camera or light emitting diodes (LEDs) for damage.
  • Close the drivers door before starting the pinpoint test.
  • Position the steering wheel in the straight-ahead position before starting the pinpoint test.
D1 CHECK THE DRIVER STATUS MONITOR CAMERA MODULE DIAGNOSTIC TROUBLE CODES
  • Close the driver door and wait 15 seconds.
  • Ignition ON.
  • Connect the diagnostic tool.
  • Using the diagnostic scan tool, clear the DTC .
  • Ignition OFF.
  • Wait 10 seconds.
  • Ignition ON.
  • Wait 1 minute.
  • Using the diagnostic scan tool, perform the CMR self-test.
Is DTC B115E:97, B15E1:97 or B15E2:97 still present?
Yes
GO to D2
No
The system is operating correctly at this time. The DTC may have been set due to an previous obstruction or blockage that has been removed.​
It's the iNanny cam sensing something's blocking it. It could be intermittent. Top left side of the center Sync screen.
Abraham5G
Abraham
Houston, TX
I'm also getting code B15E1 on my new 2023 F-150, don't know what this means. I am having an issue with my bumper sensors detecting obstructions that are not there below 5 mph, not sure if this code is related to that.
