Android widget
StoneGray22
Jonathan
22 SCREW, 500A, 3.5 EB, 4x4, Max Tow, 157"
When I try to open/install the apk, I get an error message stating "there was a problem parsing the package".
kennelh
kennelh
Louise and Ken
Northern California
2021 Mustang Mach-E, Premium RWD
Unfortunately that seems to be a generic message. What's your phone and which version of Android do you have on it?
StoneGray22
Jonathan
Z2 Force, I was able to get past that error by going a different route, I think. But now I'm getting a pop up asking to allow permission for a different app already installed on my phone.
kennelh
kennelh
Louise and Ken
Northern California
The only interaction is should have with other apps (that I can think of) would be when you assign apps to the two buttons on the bottom left, but that's only to access their name and icon.
kennelh
kennelh
Louise and Ken
Northern California
What version of Android are you running? Someone on the Mach-E forum had the same message on Android 9.
Static
Dan
Kentucky
F150 - 2021 XL 4x4 Supercab
Some behavior I've noticed, the distance to empty is accurate now, matches what is in the fordpass app, but it has dropped below the previous errant report of 254. However it seems like my truck doesn't update the status after I've finished driving, so my last status in the widget is likely the last status before I shut the truck off. It shows the door locked, but alarm not armed, and the voltage is 15. Now, if I send a lock command to the truck from the fordpass app that seems to force the truck to update the servers so it can confirm the lock command, but at that point the gas tank level goes away so I imagine it doesn't get a good report when the engine is not running. After the lock command the alarm also reports as armed and voltage drops to 12. Wether any of this has anything to do with the fact that my truck is a base model xl, or that I haven't gotten any power up OTA updates in a long time, I don't know, but that's where I am right now.
StoneGray22
Jonathan
Also Android 9.
With regard to the app permission, when I click on the apk download, I first get a message that is about restoring a backup, I click restore, then I get a second asking message for external storage write permission, when I allow that, the next message is asking for a different, currently installed app to have access to photos, media, and other flies on my device.
I haven't "clicked" any of the buttons beyond this point.
kennelh
kennelh
Louise and Ken
Northern California
Also Android 9.
Ok. I didn't target any APIs earlier than Android 10, so it hasn't been tested on Android 9. I will buiild a virtual machine tomorrow to see if targeting that version has any issues.
kennelh
kennelh
Louise and Ken
Northern California
I just pushed a version with the minimum SDK for Android 9. I ran it through some quick tests on a virtual device and everything seemed to work, so you can give it a field test on real hardware.
roadPilot
SE Michigan
Widget seems to work fine, except the graphic on the right is a Mach-E. It does say "Ford F-150" in the upper left.
Samsung S21 Ultra 5G
Android 12
kennelh
kennelh
Louise and Ken
Northern California
Android 12
Curious.... what are the first 7 digits of your VIN?
Kanuck
Winnipeg, Manitoba
Retired Electrician
I received an update this morning and everything seems to be correct. I do have one question, unrelated, I keep getting this OTA message. Does this mean I will be updated between now and the 3rd of March?
Thanks for your time and effort in developing this widget
Ford F-150 Android widget Screenshot_20220228-141658[1]
kennelh
kennelh
Louise and Ken
Northern California
Looks like the OTA is close; I forget the stages but I think "artifact_retrieval_in_progress" means it's being downloaded. That follow something like "delivery_queued" when it's preparing to download. Hopefully next is "success" and not "failure".
Note that the notification will keep popping up until you click on "Clear Alert".
Kanuck
Winnipeg, Manitoba
Retired Electrician
Thanks again.
