Always on ICE mode
Mosey
2021 F-150 Powerboost
How do you keep the Powerboost engine running? I want to check my transmission fluid level and the engine must be running and in park. Only way I can do this now is to have someone in the cab constantly blipping the throttle a little. Thanks.
If you disconnect both 12v batts for a few minutes, on first start it should just run.
nikon858
Justin
Jupiter, fl
23’ f150 platinum powerboost
Tow mode will keep it running. But it has to
Be in gear.
JoeRedFly
Joe
2023 F150 PB
Working
Just crank up the ac and heated seats, it'll run the ICE periodically, enough for you to quickly check the fluid anyway.
JoeRedFly
Joe
2023 F150 PB
Working
@Mosey Also turn off the faster eco idle in the vehicle settings. That way it will need to run the ICE longer to charge.
imnuts
Dirty Jerz
'21 502A Powerboost 4×4
Facilities Engineer
I don't have it bookmarked, but @Snakebitten has posted the procedure for how to keep the engine running to check the transmission fluid level a couple times here.
