Warden95
- Thread starter
- #1
Forgive me if this has been posted somewhere else but I look around and couldn’t find much.
To start take off the vent trim piece. It’s really easy you can reach down in the cavity in the engine compartment and pinch the top few spring pieces to help things along. There is sticky gasket to gently pull up with it.
Inside you can see the black rubber grommet. That circular area above it was soft but not sure on that.
Took out the glove box and it’s tough to see behind the air filter but looks like the grommet is right there for easy access into the cab
Looking up from inside cavity there were several access areas straight to battery
When I run my 1/0 GAUGE soon I’ll report back if successful.
