Adding Rear Locker to 2020 F150 XLT?
Surfnbike
Muhtayo
Socal
2023 Bronco
Is it possible to add a locker to a 2020 F150? I am planning on adding 35s and need to regear anyway so I figure I may as well throw a locker in there since the truck wasn't equipped with one. My last F150 had an e-locker and it was a life saver the few times that I needed it.
If anyone has any experience doing this to their truck I would great appreciate it. Did you get a hold of a Ford factory locker or go aftermarket, eg. ARB/Eaton? Thanks.
The_Auto_Tech
Cody
Des Moines, IA
2022 XL 4x2 3.3
Currently going Eaton TrueTrac and 3.31's on my street truck, so there's options. Depends on if you want a full locker, or an LSD.
TN_Ryan
Chattanooga, TN
2021 F150 XLT RCSB Oxford White
I have the factory e-locker that came out of my truck if you are interested...it's for the super 8.8 rear end. If you have the 9.75 rear end, then mine won't work.
But yes it is possible, depending on what your rear end has now for the bulkhead connector that passes the e-locker signal through the rear end housing you may need the bulkhead connector, and of course a way to engage the e-locker. You can do it with a switch, or set it up to work like factory if you wanted to go that route.
