Adding a subwoofer to '24 XL Base
bflan2001
Brian
CA
2024 RCSB 4x4
Machinist
Je1279
Jared
Upstate NY
Yes that is the correct t-harness for your truck. If your amp doesn't accept high level inputs, you will need the LC2i to convert the high level front channel inputs into low level inputs for your subwoofer(s).
Je1279
Jared
Upstate NY
I'm guessing that you know this already, but you will also need the appropriate gauge wiring kit for your amp and a set of the correct length RCA cables to go from the LC2i to the amp (if not included in the wiring kit). Also, where do you plan on mounting the LC2i and the amp?
JCsTruck
Worcester MA
Just curious but where are you going to fit a subwoofer in a 2024 RCSB. I installed a 10” subwoofer in a ported enclosure in my 2014 RCLB years ago. I custom built the box myself using BassBox Pro and installed it behind the seats of my regular cab long bed however, that truck had more room behind the rear seats compared to the current generation by 4 inches. I had a full 3-way system with JL Audio mid woofers, Audiofrog GB25 mids and GB10 tweeters, JL Audio integration DSP and Twk 88 with amplifiers for that system and it sounded freaking awesome after tuning it with REW. It was so clean and clear even at the highest levels and it would send chills down my spine when songs like “ dire Straits, money for nothing” came on ?.
Gatorbud
Jason
NoFlo
2025 RCSB F-150
I was poking around and found this. Your limited to 4 inches for mounting depth.
https://www.mtiacoustics.net/#!/MTI-Acoustics-Budget-Behind-Seat-Build/p/711320829
JCsTruck
Worcester MA
