Adding a power seat question for the guys that have done it?
MGF150
MGF150
East Texas
2024 F150 XL
Is there an issue if the seats are memory? I am unsure if mine are, I just picked mine up earlier and already tore apart the pass side, did you swap airbags or just leave the bags in from the power seats? Mine are heated too, I wish we had a solution for getting them to work through OEM integration.
No issue with memory, that is built into the truck, not the seat. Use the airbag and occupancy sensors out of the seats that came in your truck and it all should work fine. The heated seats can be used, you just have to do a little more Wireing and programming. Just do a search for adding heated seats.
CincoBlanco
Oregon
2023 f150 XL
Im also doing the same. I picked up pair of 8way power seats out of a 2024 wrecked f150 to my surprise they worked only was in 120 for both, but I'm curious what else needs be swapped from stock seat over to the new one?
XLT22
GA
2025 STX 200A
Swap your seat foam/upholstery. The airbag will come off with the upper seat foam/upholstery just need to take two nuts off the studs. No reason to try and take it out of the pouch. Pay attention to the airbag connector, there's a tab on the backside that has to go up the same as the one facing you.
You'll need to make one cut in the seat back fabric to route it by the factory manual seat adjustment cable. It'll make sense when you see it. There's no occupancy sensor in the driver seat, only passenger. Use your occupancy sensor on the new seat. My own $.02 is to cut a piece of 1" soft craft foam the size of the seat spring and put it under the cushion. These seats have felt like sitting on a bucket since 2021 and that helps.
CincoBlanco
Oregon
2023 f150 XL
Thanks! Just one thing the seats I purchased are from a 24 but my truck is 23 saying that would i need a 24 airbag or would my originals work? Just asking as iam waiting on oem leather seat covers and dont wanna put everything back together to then having to swap em out.
Work as in no lights on cluster
XLT22
GA
2025 STX 200A
Work as in no dash on the cluster
Use your airbag. All you need to do is remove the two nuts holding it to the frame, disconnect the connector (remember there are two tabs to push up) and it comes off with the seatback foam/upholstery.
CincoBlanco
Oregon
2023 f150 XL
Awesome 👌 they should arrive Wednesday gives me time to take off oem seats and swap em out the 24 seats were for practice so I'm comfortable with taking it apart now. Also yeah these stock cushions are so horrible dont know
CincoBlanco
Oregon
2023 f150 XL
Although I'm still looking to see how I can power the passenger side as there's no power going to it anybody figure it out?
CincoBlanco
Oregon
2023 f150 XL
Thread says to tap into dirvers side in order to supply power to passenger side I'm looking for a harness that taps into fuse box or bcm
XLT22
GA
2025 STX 200A
Way easier to tap power from the driver seat and run it over. Do not use scotch locks.
JGDallas
Jaideep
Frisco, TX
F150 STX
Self Employed
What's the next thing I should do? I have a 2022 FTX with manual cloth seats. Gor 2022 Lariat leather seats. Swapped driver seat (not cover/harness/airbags .... just took out the STX seat and placed in the Lariat seat). The seat doesn't move/tilt. Made sure male connector from floor is supplying power by placing the passenger seat in the driver area, connected the harness and yes, passenger seat functions fine. Now what?
CincoBlanco
Oregon
2023 f150 XL
I also did the same tried both seats on drivers side to make sure they both worked or else id have useless seats
Id check any lose plugs or snipped harness
XLT22
GA
2025 STX 200A
If the Lariat seat has the driver seat module it won't work. You "might" get away with swapping the seat harness and buttons with a 10 way non-memory version. The passenger seat harness is the same except for the addition of an occupancy sensor. You'd still need new buttons since those are different.
