501A to 502A
dolsen
KY
2022 Rapid Red 701A
I have no idea why you got rear tail lamp faults
You can’t run the calibration . It requires the sensors
Jerryh45
Gerardo
High beams are not related to the calibration.
Im not sure what harness or forscan changes you made to the BCM.
Jerryh45
Gerardo
I stripped a platinum core support harness and I pin them to there location
anything in particular I need to check on the bcm with for scan
dolsen
KY
2022 Rapid Red 701A
I won’t be much help with the halogen to LED P conversion. It’s similar but not the same as the upgrade I did
dolsen
KY
2022 Rapid Red 701A
The auto level doesn’t prevent the headlamps from working with respect to high beams, turning beams, and even glare free
Jerryh45
Gerardo
I been told but I still want to do the full conversion
dolsen
KY
2022 Rapid Red 701A
That’s good to hear! I just wanted to make sure you didn’t think that was going to solve your current issues
evoslayer
MI
'22 F150 XL RCSB 5.0
Hi, do you have the part numbers for the wire harness parts on the powered column? I have the column just need to wire it up now. Thanks.
dolsen
KY
2022 Rapid Red 701A
I have the connector part numbers, but the wiring harness is all part of the IP harness, that’s not something you’ll want to replace just for this. I’ll have to get it when I get home tonight though
tony72cutlass's'
Tony
Halifax
Up to about $1740 in total cost as of right now (including shipping and taxes). I can retrofit the heated steering wheel, the rain sensing wipers, and heated rear seats with the parts purchased. I still need the Powered steering column (any help on PN would be greatly appreciated!) and then the rest of the parts for the LED projectors. MOST of the stuff I bought from Varsity ford, as they seem the have the lowest prices on OEM parts (FordOEMPartsOnline was about $25 cheaper for the parts, but I saved about $30 going with Varsity Ford after shipping and taxes)
EDIT: everything in green is purchased
Hey Dave - did you ever retrofit heated front seats? I'm considering switching to lariat front leather and only want to do heated fronts (controlled via the HVAC module)
