400w 120v Bed Outlet doesn't power much
Gonzo
2021 F150 XLT 302A
My truck is an XLT 302A, it does not have Pro Power buttons anywhere, so I assume it does not have Pro Power. The window sticker shows it has "Onboard 400w Outlet" and the it has an outlet in the bed with 400w, 120v with the light always on. This outlet really doesn't run much expect phones, and small stuff. It would not run a blow dryer or vacuum. Am I doing something wrong or is this just a standard plug like on the inside and worthless for actual power tools? Just trying to get to know the trucks capabilities.
Gonzo
Gonzo
2021 F150 XLT 302A
400watts will not run any major power tools but good for charger for battery tools.
Well that's good to know. I was under the impression it would run more when I purchased the truck.
Plat_2021
Dennis
MN
2019 F150 Lariat Sport, 2021 Platinum (on order)
Network and Security Consultant
There are larger inverters / generator available as a option... Non-Hybrid 2000 Watt, Hybrid comes with a 2400 Watt and a 7200 Watt is also available on the hybrid that can certainly power a number of power tools. The 400 watt is what has been in the truck for years but a external plug was added in the bed.
Agashi25
Arban
Chicago
2015 Mustang GT PP CO
Interesting. Not sure I will eve actually use the 110 in the bed but I am curious how easy it would be to upgrade the inverter.
discothan
SW Michigan
2021 F150 XLT
The 2.4K and 7.2K only comes in the hybrid.
The battery package is engineered completely different between the EB and Hybrid.
Craiger
2021 xlt sport 5.0
trucker
Can anyone tell me how I can get the bed outlet to stay powered up with the truck off?
Stagalv
Galveston
2021 F-150
Ship Agent
I find that my truck has to be running for the plug in the bed to be active.
ptricky
Texas, USA
2021 F-150
Indeed - the vehicle must be on. If you have the PowerBoost hybrid then the gas engine will cycle as needed. Additionally, "generator mode" needs to be enabled from the cabin (touch screen or hard button). It does not appear possible to use remote start and the green hard button in the bed (or FordPass app) to activate generator mode.
Stubblejumper
Alberta
You need to look at the wattage rating for the items that you intend to power up. A hair dryer usually takes 1500watts, which is almost four times what the 400w plug is rated for.
Tecdiver
Dana
Michigan, USA
2021 F150 Lariat PB
Corporate shill
You might be able to use FORScan to tweak the timeout. This list is WIP. You will need an ODB-II device and register with the FORScan community. Its an easy process to program the modules, just be sure you follow the instructions - backup the original config, etc.
Here's the link: FORScan - 2021 F150 - Google Sheets
KGB81
21 F150
My '21 lariat has a DOA outlet/inverter. Light comes on randomly without anything plugged in then goes off. Mostly is off.
texag
CA
2010 Silverado
How many Watts would an air mattress pump pull?
