3.5l Ecoboost first tow observations & concerns
780
Todd
edmonton
No, you can select Turbo Boost gauge as one of two selectable gauges at the top of your screen through the Menu accessed on the steering wheel. At least you can with my XLT 302A.
Perfect. Thank you.
UGADawg96
JAX, FL
I don't have that option on my Nov 2021 build 302a :(
Ford F-150 3.5l Ecoboost first tow observations & concerns 1646773514190
trojandawg3
Shannon
Northeast Georgia
2022 F150 XLT Sport 302A FX4 SuperCrew 3.5 EB
Controls & Automation Specialist
I didn't think mine had it either, but I finally found it. Mine is a 22 though...
pavementends
pavementends
Idaho
Enginerd
Mine's a 2021 built in Nov too. It's there but buried under a bunch of clicks. I'll try to put together a walkthrough tonight...
  • Like
Reactions: 780
pavementends
pavementends
Idaho
Enginerd
MENU button on steering wheel, Settings, Configure Gauges, select Left or Right Selectable Gauge
pavementends
pavementends
Idaho
Enginerd
What I posted is what I have after menu/settings. Only those two next options.
You have another page of options, push Up or Down arrow to scroll between pages. I can tell by the narrow blue line on the right side of the box.
UGADawg96
JAX, FL
When I push up or down it toggles between Neutral Tow and Vehicle Maintenance. It doesn't go higher or lower beyond those two.
Ford F-150 3.5l Ecoboost first tow observations & concerns i-dont-know-im-not-sure
UGADawg96
JAX, FL
I stand corrected. After another attempt, I was able to get to a second screen to find more settings. The dash UI/UX could use some polishing. I now have boost where oil pressure used to be on the left. Thank you!
daemonic3
Terry
Sacramento, CA
2017 F150 3.5EB
Nice! Turbo is such valuable information. Who even knows what to do with Oil Pressure anyway? Mine could say "eleventy billion pressure units" and I'd just be like, "ok".
imnuts
Dirty Jerz
'21 502A Powerboost 4×4
Facilities Engineer
How often is oil pressure in a middle ground? I feel like it's either going to be good or bad. I've never seen someone with borderline oil pressure.
DT444T
Jake
21 AMB Powerboost Lariat
Meat servo
Depending on the truck there are menus that you can't be in when moving or in any gear except Park. Since you're in Drive, there.
