XLT22
So you’re pulling the ‘ol “I reject reality and substitute my own” defense.On similar sized aircraft engines with similar sized turbos, the issue of coking and scoring of the bearings is a known problem. Unless there is a designed in feature to provide lubrication during shutdown there is a real risk of damage. I'm sure they spin down quickly... but when you start from 100,000 rpm it can still take a measurable amount of time. Appreciate your assurances but they don't ring true.
There is no scenario happening as you describe unless someone sits in the cab flooring the throttle while manually pulling the wastegates shut with a rope while shutting the engine off. Under normal operating conditions compressor speed is always going to be controlled with wastegate position and throttle valve angle.
