23 Lariat. Underwhelmed by the fog lights.
Davexxxx
MO
Last eve was the first time I'd driven this truck in meaningful fog.
I was underwhelmed and had to hit the switch a couple times, just to make sure I was turning them on. I was.
Far as I know, they're the LEDs, as the light is bright white and come on directionally, when making a sharp turn, which I like very much.
In auto mode, when the high beams come on, they go off but come back on, when low beams, kick back on.
But also in auto mode, the high beams came on once while the fog was dense and had to hit the manual lever selector to return to low beams. That must over ride auto, because they stayed that way the rest of the trip. Which is fine.
The function is fine. The underwhelming part, is the reach. As mentioned, it was actually kinda hard to tell that they were even on. A slight extra bit lighting to the side, is other than the indictor on the dash, all that was noticeable and barely at that.
jkosh22
Jesse
minnesota
2021 Ford F150 Lariat 5.0L
automotive technician
I absolutely agree with you. You can change the module coding in FORscan to allow your fog lights on with high beams. Aka Bambi mode. But the fog lights are very underwhelming. Disappointing to say the least. But the Lariat dynamic bending headlights are fantastic.
SilverPigeon
Australia
They have a height adjustment to bring them up to a usable level 🙂
Davexxxx
Davexxxx
MO
Cool! I knew the headlights do but didn't know the fogs were adjustable.
Same type mechanism? What do I look for?
Davexxxx
Davexxxx
MO
I don't have the full bending lights. That was 502A vs. 501A but the fogs turn on directionally, during a sharp turn. A half measure I guess but I'll take it.
SilverPigeon
Australia
Highway 11
'23 F-150, '24 Bronco
Yeah, once properly aimed the the fogs are great. Takes a few minutes with a 10mm socket if I recall correctly. Don't even need to take your front wheels off.
jfalat
joe
akron ohio
2024f150 crewcab xlt 3.5
truck upfitter
i adjusted mine to shine about 15 ft in front of the truck.. makes a big difference.
crazywayne311
Wayne
Hampton Roads, VA
CTMO
i adjusted mine when i adjusted my headlights after my level. made a huge difference
Davexxxx
Davexxxx
MO
Thanks a bunch guys.
Didn't set a timer but I'd agree with those who mentioned 30 mins. Maybe less.
I did remove the 2, 7mm screws (makes it much easier) and was able to do it all from my brake seat, with a 10mm. No tire turning, or anything else needed.
A couple in the other thread, mentioned less adjustment available on the passenger side, so started there. Raised until it lost thread, then tightened it one full turn. So, ~4 full turns? Raised the other to match. That one was tight enough that it needed the ratchet but just barely.
I'm sure its better and will test soon.
Jerome10
North Idaho
They’re completely worthless. Even when cornering do absolutely nothing.
maybe I need to try the adjustment…
na8rboy
Northern WI
23 powerboost lariat fx4
GC
They are technically driving lights, not fog lights.
Ricksc
Rick
Bay area
Mine were aimed straight down. Took like 4 full turns to bring them up to work.
Davexxxx
Davexxxx
MO
From underwhelmed, to pleased. Now I know why they call it Bambi mode. Thanks again.
