Cranberry66
- Thread starter
- #1
Hey everyone, not sure if this is the right section for this but looking to see if anyone has some insight on a bcm programming I’m doing for a 22 tremor. The BCM is New from the dealer, I am using FdRs for th BCm PMI procedure, and I also have nastf credentials. However, when doing the PMI process it boots itself out. Tried doing a BCM configuration but it won’t work unless the PMI is done. I went into Forscan and inputted the BCM build data but when I go to write it it fails after block 34. I tried to go into the gateway module and run the TRON function but it also fails and I get an error NRC 31. So with that being said I’m not sure where to go from here I feel like I’ve tried everything, and I have a used bcm in route to see if I can configure that and then be able
To do the pats parameter reset in the PCM. Truck doesn’t start until all that’s done. So any insight would be greatly appreciated
