Reverse Brake Assist not available See manual after Forscan programming
ksballen
Brendon
2022 F-150 Lightning
Hello all,
I went in and did my first programming (on this truck have done it on my last 2) on 2022 Ford Lightning. I did 50/50 camera. anti glare lights, some BC 1.4 features, cameras always on, etc.
Everything seemed to work well until I parked and backed up and got the above error. It has happened each time I have backed up since. I have verified most all of my changes to make sure they are correct. Any idea any specific change that might effect this or any settings to look at specifically? thanks in advance
ksballen
Brendon
I need to run them again which I will do tomorrow as I am not sure if this one came before or after (it very well might have been after I can't recall when I scanned them last). But this is it. Maybe I need to recalibrate the ipma camera in forscan?
Code: B1578 - Digital Park Assist Camera Vision System
Additional Fault Symptom :)78):
- Alignment Or Adjustment Incorrect
Status (-2F):
- DTC Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Image Processing Module A
