My 21 lariat still has them. They are the electronic ones and not the vacuum ran ones like the older models.Something worth noting, if your truck has 4A it doesn’t have IWEs in most cases. When Ford implemented the 4A transfer case, they removed the IWEs and instead the front driveline is always spinning even when in 2H. This is why you’ll find a lot of people on here recommending early/often differential services in the front, as this spinning without load does tend to cause the front diff to wear out if not taken care of.
In general, here’s where you’ll find each of the following:
HAVE IWEs: XL, XLT, Tremor w/HI-Lock Transfer Case, Raptor
NO IWEs: Lariat, Platinum, Limited, King Ranch
Intersting, I don’t see why there would be a need for IWEs if the front end is still spinning. The whole point is so that when in 2H the transfer case and IWEs can be disconnected and leave the front driveline motionless. I wonder if they’re true IWEs like on the non-4A transfer case, or if they’re some sort of placeholder.My 21 lariat still has them. They are the electronic ones and not the vacuum ran ones like the older models.
I think I did read somewhere about the front always spinning in some form like you are saying
So I tried to pull skid plate / fiber guard to change front diff fluid… those bolts are on TIGHT! Do you remember having any trouble getting that stuff out of the way!? I see they attach to speed nuts and I really don’t want to strip. Also, everywhere says it’s a 13mm but that’s no where close. My 15mm fits but not snug and nothing else seems to work.My 21 lariat still has them. They are the electronic ones and not the vacuum ran ones like the older models.
Yes, some sounds just baffle one, been there, done that. I chased a snapping/popping noise on an older car that turned out to be a U-joint eating itself. On the IWE side remember that the IWEs are engaged or not. If they're making noises when engaged, you've got a real problem as there should be no relative motion between the wheel side gears and the input side. So if they had been making noise then the "grind-me-a-pound" effect is in full force and complete replacement would be the only option.Crazy
Lesson learned and glad it wasn’t anything worse.
So new tires and an alignment in your future?
The front axle is not spinning. If in 2WD you can hand turn the propeller shaft easily. You need to do this to pull gear lube out the fill plug when changing it out since there is an internal that can block feeding in a suction tube.Intersting, I don’t see why there would be a need for IWEs if the front end is still spinning. The whole point is so that when in 2H the transfer case and IWEs can be disconnected and leave the front driveline motionless. I wonder if they’re true IWEs like on the non-4A transfer case, or if they’re some sort of placeholder.
I have confirmed for certain, that on my ‘24 XLT the front driveline does disconnect and stop spinning in 2H, while on a Lariat with 4A it did not and kept spinning
On the non-4a trucks it stops spinning, however I'm pretty sure that with 4a the whole front driveline still spins.The front axle is not spinning. If in 2WD you can hand turn the propeller shaft easily. You need to do this to pull gear lube out the fill plug when changing it out since there is an internal that can block feeding in a suction tube.
May be so. I have only observed non-Full Time 4WD. Having pulled the gear lube out with a suction setup, there is a rotating member inside that has to be rotated to clear a path for my suction tube. It rotates by hand easily.On the non-4a trucks it stops spinning, however I'm pretty sure that with 4a the whole front driveline still spins.
Are you able to confirm the front half shafts Do NOT spin in 2H? Am I crazy? I tried to video low speed sound and noticed they turn in all drive modes. I know they eventually changed this but for a 21 build it should be separate yeah?My 21 lariat still has them. They are the electronic ones and not the vacuum ran ones like the older models.
No I can but I think they do spin in 2WD. They just don’t have any power going to them until you turn on the transfer caseAre you able to confirm the front half shafts Do NOT spin in 2H? Am I crazy? I tried to video low speed sound and noticed they turn in all drive modes. I know they eventually changed this but for a 21 build it should be separate yeah?
Hm ok that might make sense.No I can but I think they do spin in 2WD. They just don’t have any power going to them until you turn on the transfer case
