21-23 Powerboost Fox 2.0 2” Level Kit
Garbarino
Johnny
CA
2022 Lariat SuperCrew 4x4 Powerboost Sport & BAP
After speaking to a sales rep at Fox just now, he said the following applies to the 21-23 4x4 Powerboost. Will raise the front 2 1/4” to 2 1/8” which after time will settle to 2”.
A) Front = Part # 985-02-015
- The recommendation of lowering
the shock perch not applicable to
the Powerboost due to added
weight.
B) Rear = Part # 985-24-029
Note: The only difference between this kit, which is the same as their 2015-20 version, and the Roush is the Roush comes with plastic roost deflectors. No performance difference.
He said Fox is in the process of updating their website to show the correct part numbers for the Powerboost which does not use the same spring rate as their Fox 2.0 kit for other F150 21-23 models.
johnnywattage
Alamo
F150 Lariat PB
Did you install the Fox set up on your PB? If so, can you send before and after pics?
mxwrk
Max
Huntington Beach
2022 Lariat Powerboost
I got these parts on my Powerboost last summer. Not the best pics for comparison but here ya go.
Ford F-150 21-23 Powerboost Fox 2.0 2” Level Kit IMG_4948
Ford F-150 21-23 Powerboost Fox 2.0 2” Level Kit IMG_4204
Ford F-150 21-23 Powerboost Fox 2.0 2” Level Kit IMG_4963
Ford F-150 21-23 Powerboost Fox 2.0 2” Level Kit IMG_4995
Ford F-150 21-23 Powerboost Fox 2.0 2” Level Kit IMG_4964
mxwrk
Max
Huntington Beach
Looks great. What size wheels/tires did you go with?
Thanks!
wheels: Method 316 model (17x8.5, 0 offset)
Tires: BFG Ko2 (285/70 17, load range C)
oldramnewford
Chase
Eagan
2023 F-150 Platinum Powerboost
medical provider
How is it holding up mpg wise? Rubbing? Any regrets. Did you do the work yourself or have a shop do the lift?
safety_3rd
Patrick
Austin
22 Powerboost F150 King Ranch
Does your upper control arm squeak at all?
