These are the part numbers that I ordered. Disregard the pillar and keypad ones unless you want to add those tooI'm looking to do this for my 25 Lariat PB and I'll be going the factory harness route- thank you @jokey for confirming. What are the specific part numbers for the left / right LED fog lights? Not sure if MY24 and MY25KR have the same part #s or if it matters. I'll be going OEM if possible- I don't want to push my luck with cheaper alternatives.
Did you use the harness part number from the earlier posts? If the plugs are at the ends of the bumper I'd assume its for the distance sensors on the outsides of the bumper for the platinum plus models or models with the park assist.I just did the swap on my 2025 Lariat using the platinum harness and new DRL fogs from Ford. Parts came out to just about $815 and took about 3 hours to remove the grill, bumper and all bumper components to install the harness and lights. I noticed the platinum harness has 2 extra plugs that I did not use, do you guys have a wiring diagram to see what those are for on a platinum?
right in the middle of harness there was two extra plugs near main plug.Did you use the harness part number from the earlier posts? If the plugs are at the ends of the bumper I'd assume its for the distance sensors on the outsides of the bumper for the platinum plus models or models with the park assist.
This is what I could find real quick. Not sure why you wouldn't have a spot for those plugs to go though.right in the middle of harness there was two extra plugs near main plug.
Thank you. Looks like I’m pulling the bumper off again tomorrow to see what I missed, looks like the active grille shutter and a parking sensor. Everything seems to be working and no warning lights came on.This is what I could find real quick. Not sure why you wouldn't have a spot for those plugs to go though.
Do you happen to have the 5.0? I think there is something for the bypass valve in that harness for the ecoboost/power boost trucks.I noticed the platinum harness has 2 extra plugs that I did not use, do you guys have a wiring diagram to see what those are for on a platinum?
yes its a 5.0 lariat 502a. I just looked over the harness I removed from the truck and I only had 9 plugs in the bumper- 4 park sensors, 2 fog lights, 2 actuators, 1 CCM.Do you happen to have the 5.0? I think there is something for the bypass valve in that harness for the ecoboost/power boost trucks.
They have to pay for all the recalls somehowThis is bs, an 80k truck should not come with XLT fog lights.
