Buyer2021
- First Name
- Alan
- Joined
- Feb 9, 2021
- Threads
- 49
- Messages
- 3,136
- Reaction score
- 5,646
- Location
- central TX
- Vehicles
- 2022 Lariat SuperCab and 2005 XLT SuperCab
- Occupation
- retired!
FWIW here's my '22 Lariat 4x4 Max Tow (full description in my sig block) with the 1.25" non-tapered (measured) OE spacer blocks removed and 1.25" shorter 2WD bump stops installed (retains full suspension travel). Truck has no front lift/lowering, stock suspension height with Billstein 5100s..
The result was still not quite 'level' (still a slight forward slope at the bed rail) with no load. Measured pinion angle is actually slightly reduced from OE.
I tow a 5500# GTWR 5th-wheel RV with ~750# pin weight (per CAT Scale) + ~100# total hitch assembly weight and with that both the trailer and truck settle nicely to 'level' (which was the reason for the block removal, previously the trailer ran slightly nose-high with the hitch in the lowest position).
I track mileage based on odometer-miles/fill-gallons at every fill-up since new. There has been no measurable impact on my average MPG (~4k miles before mod; ~9k miles after).
For my use both daily-driving and towing there's absolutely no downside in removing the spacer blocks. Yes, I expect that if I ever loaded it to the max payload there might be some slight 'reverse squat', but that's not going to happen in my use.
(Pics are obviously not on perfectly level ground but I was on a level-slab when doing the mod and taking all of the mentioned measurements using a digital level)
