2023 Sync4 Screen Display Brightness Issue
F-150_Fan
Emery
South Carolina
2024 F-150 Darkened Bronze Lariat 4WD 5.0, 2013 F-150 Ruby Red Lariat 4WD 3.5eco
Interested if anyone found a way to deal with this.
Based on my experimentation with my 2024 model, if I increase brightness or dimness of the dash using the adjusting buttons on the left of the dash, this also affects whether I can dim or brighten the center console screen.
My problem is the dash is far too bright at night (the center console monitor is as well), even though I have the dash set to max dimness using the buttons on the left of the dash. I also have the center console settings as dim as they will go.
But, the area between and around the gauges is still that blueish color and is too bright - affecting night vision of the road.
Has anyone figured out a way to actually dim the gauge cluster? All I really need to see are speedo and gas, honestly.
TIA
SilverPigeon
Australia
In the APIM there is a setting for Calm Screen which gets driven to the IPC:
7D0-10-01x*xxxxxxxx--Oil Life (OL) • Calm Screen – Cluster IoD config (CSCID) • Trip 1 – Cluster IoD config (TCID) • Trip 2 – Cluster IoD config (TCID)
I would try it out, but my truck is in for service. If you have FORScan you could try that to see if it meets your needs, otherwise I'll try it when I get my truck back ?
