2023 f150 5.0 engine noise , is it normal ?
Hermanroman
Roman
2023 ford f150 rcsb supercharged
Welder
Hello you guys , was wondering if this tick/tap is normal ? My truck has 3200 miles , I’ve never noticed it till today .. it’s a 2023 5.0 f150
JExpedition07
James
Buffalo NY
2023 F-150 STX 5.0L V8
Sounds like the HPDIP (High Pressure Direct Injection Pump) that is fired off the cam on the passenger side. It is loading the injectors at 3,000 psi so it’s a bit noisy. Normal id say. Also could try turning your defroster off, sometimes A/C compressor clutches make noise. Mine for reference if the video loads:
Hermanroman
Hermanroman
Roman
Welder
hello , would you say yours ticks the same way ?
stevemcbo
Steve
2023 F150 FX4 Powerboost
Totally normal 5.0 sound. They all click or clack. I have owned three of them and have friends who also own them. Some with over 170,000 miles. All of them make noise.
GrandGrady
Pineville, LA
2003 SuperCrew, 2022 STX
Totally normal. Mine also makes some Ticking/Tapping noises and it freaked me out at first too. Ford has referred to these sounds as Coyote-isms before. These are just loud engines nothing to worry about.
