breadnbutta
Flawda
2021 F150 Platinum FX4 3.5 EB
Yes you can.
Ok cool. Should be pretty simple then right? Just remove the tailgate work surface and access the bolts from the inside? Enough room to fit a ratchet in there? Also, does it have any sort of adhesive on it as well?
jhelrey
MN
Yes and yes.
jhelrey
MN
You do not have to take the door apart if you push the handle assembly in. Grab a pick, pull on the center tab in the hole, and loosen the bolt a bit more. It will pop back out.
breadnbutta
Flawda
I don’t quite understand what you’re saying. Are you talking about the tailgate handle? Mine is the faux handle that doesn’t move. Can you help me connect the dots here. Def wanna know any tips or shortcuts you have. Looks like you’ve done a lot of the things I’m about to do to my truck.
jhelrey
MN
I was referring to the post where you stated you had to remove the door panel, etc. to fix the assembly when installing your door handles. You can use a pick and grab the assembly vs. pulling it all apart.
This video explains it.
breadnbutta
Flawda
Oh that makes more sense. I think that must’ve been someone else. I was only asking about the tailgate handle. Did you apply heat to the emblem on the appliqué to get it off after you unbolted it from inside the tailgate?
Porpoise Hork
Bret
IT Sys Admin
How did you do the running boards? I'm wondering if they will be easy to take apart and vinyl wrap/paint them.
You can get black OEM pulls off ebay for around 170.
rapidred150
Joe
2022 F-150 Lariat
Did you just scuff the chrome, then prime and paint? Looks great
