So with the IPMA update and these changes, you’ll get the cargo and hitch cam correct?That’s why I asked them for the IPMA update.
Yes. The update and there are as built data changes in the APIM required for the cams to work in motion. The cargo cam will NOT be full screen though land will not be available in the side stack. The newer trucks have those capability. Even with the update the early truck do not
Anyone found a way to enable walk away auto lock? After 5 years of just walking away, habits are hard to break. I remember an hour or 2 later that I did not lock it.
I wish this was available. My wife had a GM product and that was awesome.
C. Mays
22 F-150 Lariat; 25 Subaru Forester Sport
Project Management
Looks like the IPMB may have to do with Trailer reverse guidance..
I have mine all working. The only problem is you only get the hitch cam and the cargo cam in motion. The others are not selectable. You can also only switch through the cameras in motion with the camera hard button. If you initiate the cam in motion.. come to a stop and then use the soft button to select the front camera I believe then it will stay on.
I used the 21.5 trucks as a guide for the cam in motion. My entire set up is after the fact anyway.. I didn’t have 360 or 12” from the factory I added it all. Along with the cargo cam.
Jesse - Do you happen to know if there is a way to disable the "engine start chime", or whatever they call it?
Im sorry I dont. I havent really looked into though. Are you just talking about the chimes in general?
C. Mays
Project Management
I've got most of the chimes disabled, it's the do da do chime at startup that is annoying. I appreciate it though!
Got ya, Sorry I dont have anything for that off the top of my head. If I do find an answer Ill pass it along
Canadianeh!
Marco
Ontario
2021 f150 lariat
I hate to be redundant here, but anyone have the correct values for the cameras at speed for a XLT 302A, FX4 ?
These values didn't seem to work for me unfortunately:
"7D0-01-04 = xxxx-FCxx-xxxx Originally = 01 in those spaces
706-02-02 = xxxF-CExx-xxxx Originally = 0, 4, C
Things I have changed, but not sure if they affect it at all (yet):
706-01-01 = xxxx-Axxx-xExx Originally = 8 and C
7D0-01-02 = Axxx-xxxx-xxxx Originally = 2"
It didn’t work. Really fuck that’s what zyvin told me he used and said it work
Caneman88
Ron
San Antonio TX
2021 Powerboost F150 Platinum ,MB GLC 300
Pella Windows and Doors
got this from another site:
Here's some things to try:
IPMA 706-02-02 xxxB CExx xx--
APIM 7D0-01-01 xxxx xxxx Fx--
APIM 7D0-01-02 6xxx xxxx xx--
APIM 7D0-01-04 xxxx EDxx xx--
Do an APIM reset under the wrench icon after the APIM changes.
Yeah that is one thing to remember.. sync 4 units sometimes tale time for the programming to reflect. So the reset recommendation is a good one. Even then sometimes they are weird about it sticking
Canadianeh!
Marco
Ontario
2021 f150 lariat
Have you tried this yet? Does it work ?
antho
Anthony
Houston, Texas
2024 Raptor 37
Anyone able to access Strategy files? Have a issue with my SCCM and cannot get the strategy files. Forscan is saying the Strategy file should be ML3T-14C579-BD. Any help is greatly appreciated.
SCCM - Steering Column Control Module
Part number: ML3T-3F944-HD
Calibration level: ML3T-3F944-HD
2021 Raptor
Caneman88
Ron
San Antonio TX
Sapphire
Courtney
Chicago
2021 F-150 Powerboost Platinum (job 2)
I think those chimes may be your seltbelt minder. I hear “do da do” chimes when I start the truck and the belt is unfastened. If I fasten the belt then start the truck, no chimes. I’ve seen how to disable the minder without FORScan posted a bunch of places, including here.
C. Mays
Project Management
I’ve disabled the belt minder. Just tried starting the truck with seat belt buckled and sure as sh*t. No chime. That’s strange. Appreciate that.
Sapphire
Courtney
Chicago
Sounds like you can tell the minder to shut up after one chime, but not entirely. Weird. I haven’t tried turning off the minder before.
