Borgelpe
South Florida
2021 Raptor
Aerospace Exec
How about Auto global windows up on auto rain sensor detecting rain?
EatDirtFartDust
Josh
St Louis, MO
2021 Ford F-150 XLT, 2015 Lincoln MKZ
Ford service manager
Some Mercedes models do this. A convertible will even put the top up.
Never seen it on a Ford, though.
I don’t think the rain sensor/camera is enabled when the truck is off.
Littlefield82
Holly Springs, NC
2021 Lariat 502a PB FX4 5.5'
Civil Engineer
I am getting a "service procedure has been interrupted" error when trying to write the window open/close mod. Only on the DDM & PDM; BCM & APIM worked fine.
Any ideas what causes this error or how to resolve?
EDIT: I think I found the answer on one of your other posts - need to use a version newer than what's currently released.
https://www.f150forum.com/f129/forscan-14th-gen-f150s-481816/index52/#post6948351
I'm having the same issue. Did you get it resolved?
Littlefield82
Holly Springs, NC
Civil Engineer
Check to make sure you are on latest version
DDM 740-06-02 xxxx xxxx 01--
PDM 741-06-02 xxxx xxxx 01--
DDM 740-06-03 01xx xxxx xx--
PDM 741-06-03 01xx xxxx xx--
BCM 726-11-02 xx01 xx01 xx--
BCM 726-22-01 xxxx xxxx 01--
BCM 726-22-02 xxxx xxxx 01--
I'm on 2.3.43 release, 2021-09-28
Do the -- mean leave the numbers as is or delete what's there? I know that the x means leave what's there.
Whoskyle
AZ
2021 F-150 XLT
Leave the dashes, only change the number values that are different. Ex: 01
Hectort713
Hector
Houston, Tx
2021 Ford F-150 Tremor
2021 Ford F150 Tremor
Super Duty Full Brightness DRL - 726 - 42 - 01
x2x2 - xxxx - xxxx
My Tremor came with a 2K Generator, after I did the mod I got a message about my generator
Pro Power Onboard is currently unavailable. Reset the system using the SYNC screen. See owner’s manual for details.
After that I got another message,
Pro Power on board turned off.
Pro Power Onboard detected a ground fault. Reset the system using the SYNC screen.
Took it to ford service and I was informed that it’s a known software update issue, connect to Wifi and do an OTA update from home don’t have to go to any dealer, they gave me a print out about the recall. Will post a picture of the recall once I pick up my truck.
Sentinel1201
DFW
2021 F150 Powerboost
Hello @Livnitup is there a proper way to reset transmission adaptive tables? I did the reset transmission option via Forscan but tranny is still jerky. Is there more than one module that needs to be reset?
I'm surprised that the Forscan reset didn't work for you, but here are 2 methods that some have claimed resets adaptive learning :
Ford F-150/F-250: How to Reset Adaptive Memory
  1. Step 1 - Disconnect your truck's battery. Figure 1.
  2. Step 2 - Turn on your truck's headlights. Figure 2.
  3. Step 3 - Wait 20-30 minutes. Figure 3.
  4. Step 4 - Reconnect your battery and turn on the ignition. Figure 4.
  5. Step 5 - Let it idle. Figure 5.
  6. Step 6 - Test drive. Figure 6.
Subsequently, question is, how do you reset a transmission control module? Procedure Reset Transmission Adaptive Learning DIY
  1. Turn the key to position 2. You should see all the dash lights come on.
  2. Press the gas pedal all the way.
  3. Wait.
  4. Turn key to OFF, position 0.
  5. Release the gas pedal.
  6. Wait 2 minutes.
  7. Start the car and drive.
diesel97
rob
Ford Edge
electrical
Resetting it will make it jerky until it relearns
Sentinel1201
DFW
I find that my tranny gets jerky after driving 4-5k miles gently and hypermiling i.e., lots of coasting in electric and gas motor stopping and starting. I reset tranny via forscan once about 5k miles ago and it made tranny smooth again, but its gotten jerky again. This time, the forscan reset didn't seem to cure it so I was wondering if there is a more definitive way to do it.
inkspot1967
michael
Rhode Island
2021 F-150
truck driver
Just realized I had omitted the 740/741-06-03 values below on the Global Open/Close on the spreadsheet so it's been corrected and these are the values:
inkspot1967
michael
Rhode Island
2021 F-150
truck driver
i’ve tryed these codes but on bcm the codes will not stay
inkspot1967
michael
Rhode Island
2021 F-150
truck driver
i’ve tryed these codes but not luck bcm codes don’t stay
