Also on google (obviously note the best source) but it statesI stand corrected. From the manual:
“The system tunes the steering and suspension to enhance driving comfort when towing or carrying heavy loads.”
something is wrong, Transmission man needs to look at it. Or disconnect the battery let it set 15 minutes reconnect it and drive it about 30 minutes or so , see if it's any better then.Just hit 8k. Did it since day 1.
That's True !!Not to be rude but read your manual. Tow haul does nothing to steering. All it does is hold RPM longer and engine brake. It’s all transmission related.
You mean something is wrong in that it shouldn’t be in 7th gear at 40 mph?something is wrong, Transmission man needs to look at it. Or disconnect the battery let it set 15 minutes reconnect it and drive it about 30 minutes or so , see if it's any better then.
You also get engine braking in normal mode, though you need more of a hill to go down for it to kick inYes you will get engine braking.
Ok, good. I find it difficult to believe that something that is best for economy can somehow be bad for the engine/trans.It (the Ford tuning) is all about the fuel economy.
