On the bottom of the right side small screen, tap on the stack of books at bottom of it.Nope its in night time when I switch to daytime the letters are barely visible and still a blue screen.
The side screen also doesn't work nothing shows up on it.
Take a picture of your screen like your first one showing "day" on Mode and post itHas anyone experienced a blue screen? I turned the truck off and back on and it didn't fix it.
My 2021 is just today started showing this blue screen. Any solutions?Has anyone experienced a blue screen? I turned the truck off and back on and it didn't fix it.
It's on night mode. That's what I use all the time. Not fond of daytime look. Too bright for me.My 2021 is just today started showing this blue screen. Any solutions?
I’m with you. I prefer to keep my screen on night mode all the time. The day mode is as you say, too bright.It's on night mode. That's what I use all the time. Not fond of daytime look. Too bright for me.
Nope, that won't fix it. The problem is having a cord plugged into the USB port inside the arm rest. unplug it and I'll bet the screen returns to normal. If not, the dealership will have to replace a module.Got the solution here. Hold the next track (>>|) button and the volume power button until the system reboots. Should reset the software
You're the man!! Thanks for sharing..Got the solution here. Hold the next track (>>|) button and the volume power button until the system reboots. Should reset the software
Yup, fine was doing the same thing. This was the correct answer. Fixed mine. Thanks for posting.You're the man!! Thanks for sharing..
