12" Digital Gauge Cluster (MPH model in Canada)
Highway 11
'23 F-150, '24 Bronco
Just saw a stinking good deal on the fully digital Raptor IPC for my 2023 F150. However, it's listed as an MPH cluster.
Just wondering if I can program that to work in my Canadian truck with Forscan or if the firmware itself needs to be updated with FDRS. I've seen some comments about modifying 720-04-02 for Country and Units.
Just won't want to be in the situation where I have a truck with an odometer stuck in miles in Canada. Thanks!
Livnitup
SoCal
2021 F150 Platinum
If it's a 2023 digital cluster then it would work fine for Metric units/odometer chosen in the settings menu along with the 720-04-02 changes. If you currently have the 8" screen then a 2023 8" cluster will have an air gap around it and won't look like a factory fit unless you replace 3 trim pieces.
NavyChief
Orlando, FL
23 F350
I had a Canadian F150 with the digital cluster and it was converted to MPH via the dealer so it's possible. Like was noted above the bezel and upper dash pad needs to be swapped for the cluster to fit if you were analog before.
