+1000W to 2.4Kw ProPower - PowerBoost
necser
necser
Sergey
Calgary, Canada
2021 F-150 PowerBoost Lariat
IT
Oddly, it AC starts to run, then when the comrpessor tries to kick in, AC turns off then back on (fan only).
sounds like the wiring issue. try writing to softstartrv
BaySide1
Kevin
Worcester, MA
2021 F-150 Lariat Super Crew 5.5Ft Bed
Medical Equipment Repair
I have the 2K onboard Power in my 2021 Lariat. Wish it was a bit more but it actually does what I need it too.
I repair medical equipment, have been able to repair a few tabletop autoclaves with the 2K option.
These particular units draw between 1400 to1600 Watts on average.
For those of you starting compressor motors you will most likely need more starting capacity.
So where as I can use basically an electric heater you would most likely have issues with Ac's, Refrigerators and Microwaves.
Mitch42
mitch
florida
04 ram 1500 21 Platinum Expedition
auto repair
Is it the same on for rv and house
Thanks
Qgreene
Quinton
Tampa, FL
2021 F-150 XLT PowerBoost
Good info here! I went with the 2.4 kW system just like you guys and ended up looking for a TT after it was too late to update my order. I'd love to be able to retrofit it to the 7.2 kW setup too, but just like some of you, the search for parts and such has been fruitless. Until then, this looks like a good fix. Interested to know what setup (dogbones, pigtails, etc.) you guys are using to connect power to your trailers.
