Los150
Is it worth installing a power distribution block to the rear, so that instead of running all your accessories to the battery up front, you could just tap into that block in the rear? Is that reasonable or not? I figured I'd ask, as I'm about to install a few devices and they each tell you to run the electrical all the way to the front. It just seems like one low gauge line to the back, attached to a block, would make things simpler.
I just wanted to get some thoughts before I embark on these projects, in case I can do this all in a cleaner fashion than just adding more cables to the already existing wire harnesses going up front.
Thanks
Thanks
