Davexxxx
Happened the first time the other day. Both front windows. Then the passenger worked properly but had to use the window select height part of the switch, to close the driver's side.
I've read the several threads about it and didn't find a rock solid cause. Lubing the seals, an update glitch, faulty motor, or as usual, low or bad batts?
Truck hasn't acted up since resetting the BMS, and had just taken a >100 mile, one way trip, it wasn't remotely dirty and according to Ford Pass, the last update I got, was in late March.
I can clean and lube the seals easily enough and check the batt voltage (though this time, I doubt thats it) but has anyone locked down a consistent cause?
